Hello everyone..
My Set-up :
2 195 Watt Panels http://sunelec.com/index.php?main_pa...9e568aabec83ba
1 Sunforce 30 amp 12 volt controller (yep I now know that's a rookie mistake..I'l be investing in a MPPT this spring.)
1. PowerDrive 2000 convertor (actually happy with it..)
3 ..12 Volt Marine type ( 75ah or so each) ..(yep also realize another rookie move)
1 Breaker type box..with 2 15 amp breakers
The Solar Setups Purpose
Run the Dinning Room and Living Room .. Dinning room chandilier...9 lightbulbs! Biggest change went from 9 40 wats bulbs..360 watts to 9 ...4 watt bulbs
and for emergency blackouts..which we just had one that lasted 12 hours..the solar setup allowed us to watch tv for few hours before bed and my wife was able to have lights and hairdryer in the morning to get ready for work
Dining Room : 36 Watts x 5 hours = 180 Watts
Living Room TV , Lights and Misc.. 200 x 5hours = 1000 Watts
1200 Watts used per day..I was able to do that in the summer ..but not even close now in winter..
WHICH leads us to why I went to a Vertical Mount
I first installed the panels flat last spring on our Pergala that covers our deck..worked great until around OCT and the sun not as high in the sky , new shadows etc..
So after careful study the absolute best place was the South Facing SIDE of the house..The actual SIDE of the house not the roof..The problem with the Roof is two fold:
1. The Panels are not UL Listed so I wasnt going to put them up there anyway and secondly our house is a victorian style that has like 8 quadrants of roof ..8 small..sections of roof with no sections getting sun all day
but that South facing side of the House (2 1/2 stories high) the sun beats down on it all day long..even though angle is not "perfect" pretty good as is .
My QUESTION IS: can I use the standard Unirac rails and clamps to Mount Vertical on the House siding? As a temp setup they are mounted on 16 foot 2x4's.. but come spring obviously want a more professional mounting.
I do have proper wiring and conduit etc,,
The house was built in 1916 and has the plaster and slat walls..pretty much impossible to rewire without major renovation so used UL listed electrcal wiring "raceway/rails , 6 outlets and 2 switchs from the mud room , to the dinning room and into living room.. right along the baseboards ..blends right in actually looks nice.
I will likely add on to this system..double it next year..like to have a full 2000 watts a day keeping in mind draining batteries to 40-50%..
Not really worried about payback on it ..just like having the useful daily set-up and full day backups during any power outages and of course to deny Xcel Energy a whopping $20 a month or so
So that's what I have going ..really need some ideas for permanent vertical mounting
Yes the Panels will also rise 36 inches higher.. (they are also on sperate strings)
Another Fantastic postive for vertical mount..we had 8 inches o snow today here in Minnesota..Panels are perfectly clean !
My Set-up :
