I have 6 x 120w x 12v panels in a parallel- series configuration and 3 x 120w x 12v panels in a series configuration.
If I want to place the 6 panels in a series configuration I could possibly get 120 + volts. Is it more beneficial to have a higher voltage as opposed to higher amperage in a PV array?
The panels are rated at 17v max so I estimated that I should get anywhere from 36v to 51v however I quite regularly get up to 63v especially if the weather is cool. Luckily I installed a CC that can handle 150v/70amp.
My main question is why are my 12 v panels producing more than 20v?
What is the absolute maximum voltage they can produce given ideal conditions?
