Hello Everyone,
I want to install some security systems about 1 acre out from where there is power. I hate to dig power all the way out to it ... but i will if i must.
What i need to power is
1 x Dlink GS-1100-08P - 7.88 Watts Max - 100 to 240 VAC, 50 to 60 Hz Input (Gives me a max POE budget of 64W, I will only be using 11W Max)
1 x uniquity Loco5 - 5.5 Wats - 24V, 0.5A
2 x Hikvision DS-2CD2632F-IS - Powered off Dlink Above - DC12V ± 10%, PoE (802.3af) - Max. 5.5W (7.5W with ICR on)
1 X 1 watt small fan in the control box for cooling
In the future i may add another camera or something.
I need to basically be able to power this remote station 24/7. The placement area is pretty sunny on sunny days, so that is not a problem. Mounting of solar panels would be either on an 4x8 16 foot tall post. In the winters, it can get -20 degrees (Vermont), however i believe with a charge, this is not a problem since the battery will not be idle.
What kind of system would work for my project?
