You have the math wrong. The surface area of the panel is 1.676675 m^2. If we use a theoretical number of solar irradiation at 1000W/M^2, then the theoretical total irradiation is 1.676675M^2*1000W/M^2 = 1676.675W for the given size panel. The DC rating is 270 Watts so the efficiency is calculated as 270/1676.675(using your numbers) = 16.10%
Calculating energy payback time for Photovoltaics
You have the math wrong. The surface area of the panel is 1.676675 m^2. If we use a theoretical number of solar irradiation at 1000W/M^2, then the theoretical total irradiation is 1.676675M^2*1000W/M^2 = 1676.675W for the given size panel. The DC rating is 270 Watts so the efficiency is calculated as 270/1676.675(using your numbers) = 16.10% -
You have the math wrong. The surface area of the panel is 1.676675 m^2. If we use a theoretical number of solar irradiation at 1000W/M^2, then the theoretical total irradiation is 1.676675M^2*1000W/M^2 = 1676.675W for the given size panel. Since the module efficiency is 16.10%, then the effective maximum watts for that module is .1610*1676.675W = 269.94W which is about 270watts
Could you elaborate on why the upper formula is wrong:
activeArea = DCSystemSize(STC)/(1000W/m2 * moduleEfficiency/100)
activeArea = 270W/(1000W/m2 * (16.10%/100)) = 1.677m2
That's exactly the way, one could calculate an array's active area, when both DC system size and module efficiency, are known.Comment
Thank you for the reply gregvet.
With all due respect gregvet, I think you are wrong.
You can not calculate the DCsystemSize by using overall area of your PV array.
It has to be the active area of your PV array.
Check the Solar cell efficiency wiki page, and the upper reply by pleppik:
"Solar cell efficiency is calculated by dividing a cell's power output (in watts) at its maximum power point (Pm) by the input light (E, in W/m2) and the surface area of the solar cell"
That is what I am trying to ask: Why did Solarworld's Sunmodule Plus SW 270 mono panel used the overall area(1.676675 m2) for calculation of their module efficiency whereas they should have used their active module area?Comment
Looks to me like you are both trying to separate fly crap from pepper.
Bernard: respectfully, get some background on the basics of solar energy. Also, some information about the math and use of something called "significant digits" wouldn't hurt either one of you. Anything beyond about 2 decimal places in these respects is mostly meaningless.Comment
I am well aware of the "significant digits" but the scope of this inquiry was not that and I respectfully use the OP's numbers to illustrate my point of view. Maybe my point of view was incorrect and if so, I apologize. I will bow out of this conversation before it goes off topic......Comment
Thank you for the advice J.P.M.
And everyone else too.
The solution to my initial question was found in foo1bar's reply (thanks foo1bar):
http://pubs.acs.org/doi/full/10.1021/es3038824
"Energy Balance of the Global Photovoltaic (PV) Industry - Is the PV Industry a Net Electricity Producer?"
would be the paper to look at since this is for theoretical calculations.Comment
So, if your solution is found in that paper, it looks to me like you are extrapolating observations/data about the global nature of PV and it's impact on past and future consumption of global resources and then applying those data to a residential PV system.Comment
The paper itself does not specifically deal with the definition of Energy pay back time and its factors. Instead on the very beginning of the paper, it points out a reader to these three sources:
- IEA, Photovoltaics Power Systems Programme - Methodology
Guidelines on Life Cycle Assessment of Photovoltaic Electricity. 2011.
- Raugei, M. Energy pay-back time: methodological caveats and future scenarios. Prog. Photovoltaics 2012, DOI: 10.1002/pip.1249.
- Fthenakis, V.; Kim, H. Photovoltaics: Life-cycle analyses. Solar Energy 2011,85, 1609−1628.
These further mention research for mono-crystalline silicon PV, and mono and poly crystalline silicon PV's in commercial and residential projects. Open rack and flush mounts. Some specific values for embodied energy of inverters, wirings, and flush mount profiles are given per square meter, which are somewhat similar to my project. So I will use those.Comment
