Have started the build on our retirement home which is off grid.
The "battery room" along with the inverter and controllers will be in the crawl space.
Height of the crawl space varies from 4' to 4'9".
Room is all concrete along with the ceiling-main floor. All walls will be insulated on the back side of the crawl space walls as to have no combustible in this room.
My question is how to vent the room so that I won't have any issues with the Hydrogen gas.
One thought is to have the air supply 1.5 or 2 inch pvc pipe come into the battery room high on the wall from outside.
Once in the room horizontally 7 feet then have a 90 degree taking the supply pipe to within 5 inches of the floor.
The Vent pipe could be located 12 inches beside the intake pipe or should I vent up through the roof.
Another option is use the HRV to vent. Not sure but what would happen if an explosion takes place and pushes air into the heat exchanger which could or will get into the living area.
Any thoughts or comments would be much appreciated.
Thanks for reading.
Thanks for reading.
