Some quick background. I'm on EV-TOU2 plan with a plugin and an EV. I don't use much during on-peak (at work) and use a lot during super off-peak to charge, run laundry, pool etc. For SDG&E EV-TOU2, in summer months (May-Oct) the on-peak rate is 3x the super off-peak, but in winter (Nov-Apr), it's only 1.2x. I just got my 2nd NEM bill. I started the NEM service 2/3 way through my Sept billing period, so I had a net balance of $50 (but I didn't have to pay until true-up time). For Oct, I had a generation credit of $200 (from on-peak) and used $90 (from off-peak and super off-peak). The huge credit comes from $0.49/KWh retail rate during on-peak. A "true" net metering would use the $200 credit to wipe out both Sept's $50 and Oct's $90 and leave me with about $60 credit for future use. But for SDG&E, it only used $90 credit to wipe out the current Oct's usage and left me with $50 balance from Sept and $110 credit for future use. I'm not sure if the same method is used for other CA utilities. So the following conclusion is YMMV.
So what does it have to do with installation timing? Well if I had installed my solar in the winter, my solar generation would be low to start with and with only 1.2x factor, my usage in $ term would way exceed my generation credit which will leave me with huge balances to pay month after month. Then comes summer, my generation credit would way exceed my usage in $ term which would leave me with huge excess credits. But because the credits cannot be applied retroactively, it will remain credits for future use until true-up which is end of summer. Now at true-up, I would have to pay the accumulated balance and the generation credit would be reset and wasted (because most likely I'm still using more than I generated).
So if SDG&E didn't make a mistake on my bill (by not retroactively applying the generation credit), the best time to install is in May and worst time in Nov. So I, myself, have missed it by 4 months .
This might not be a big problem for the regular solar TOU or tier based rates because the difference in $ term between on-peak and super off-peak is small. But for people with EV-TOU2 who is banking on (or gaming) the 3x factor to offset usage during super off-peak and trying to use more power than generated, solar installation timing seems very important (at least for SDG&E customers). My back-of-the-envelope calculation says one can use almost 1.5 to 1.8 times the amount he/she generates without paying a dime.
This suggestion again is based on the current EV-TOU2 rate (which can change) and assuming usage during on-peak is low and super off-peak, high in SDG&E service area since I don't have data for other regions.
