Hello everyone,
I am just completing my grid tie project and I just bought a microinverter from involar, I would like to share some information about it .
The first thing i notice is it's weight (it's quite heavy) even with an aluminium body.
It has two mc4 connecter for the solar panel and two more connectors , one can be used to connect to the grid the other connects to the next microinverter, because you can connect up to 16 microinverters in series.
The good thing about it is it's warranty it can be extended to 25 years, but in the involar site the standard warranty is 15 years.
Before o bought this microinverter the seller told me they had such a long warranty because the components inside are isolated from the air by a special foam/rubber that protects the components from the dust,water and air.This foam/rubber also has heat transfer properties, meaning it will help to dissipate heat from the components to the chassis of the inverter.
I have made a small video about it I will be plugging it to my 245w solar panel .
I will leave more feedback on this device.
