Hello,
If someone could please help me, i am currently looking to deploy an 24V off-grid solar system. I have read through the guides and sized my system accordingly, the one question i have is that my system requires and 1100AH battery bank would it be OK to have 4 6V 300AH batteries wired in series in to produce 24V The issue i have is that i have read wiring in series only increases the voltage and not the Amp hours. So will 4 6V batteries wired in series to produce 24V but remaining at 300 amp hours as the amp hours don't increase when you wire in series be ok ?
Or will i need to increase both the amp hours and voltage ? if so how will i do this as you can only increase either the voltage or the amp hours ? Any help would be greatly appreciated thank you.
