I have my solar system up and running for about a week. I can track how much my system produces with Enphase Enlighten. SoCal Edison just shows my net power. I could take the Edison net and add my solar production reported by Enlighten to get my home electricity use. I would prefer Edison to report it to me. Do they not have that info? Is all they see is the net + or - on my meter? I don't think I would call that a very smart meter! What is the best way to track your home electrical use after you have solar panels?
Most Popular Topics
How to track home use after solar install
I use the TED 5000 (The Energy Detective). I bought the TED 3-1/2 years before I got solar panels to get my usage down. -
I use the TED 5000 as well and was installed near the time of solar PV installation. Since our house is strictly electric energy(not counting solar HW), I was able to look at the previous yearly/monthly usage to compare. Since I installed the TED system, I was able to save at least 25% electrical usage by reprogramming our house thermostats to decrease electric boiler usage, install LED lights, while maintaining our comfort level.Comment
You can use a Rainforest Eagle connected by Zigbee to your SCE Smartmeter, and even get a $25 rebate from SCE. The Eagle can then feed net consumption to Wattvision, from there to pvoutput.org. If you then feed Enlighten to pvoutput.org as well, and that site can back out actual consumption automatically for you.
Yes, very convoluted, but once set up it does work fairly well...Comment
Silly Me
So net metering really does mean net metering? What is the world coming to??? I was thinking with the Enphase reporting system I would have complete details of my home use and solar production. Thanks for the Rainforest idea. I'll have to check it out.Comment
Increasing Power Production
I know there are a lot of variables that go into how much electricity your panels produce. With my system in service a couple of weeks I've noticed my production seems to be is slowly increasing as we march toward the summer solstice. I guess that would make sense, but I'm surprised that the slight increases in the length of the daylight hours could be responsible for an increase in power almost daily. Do others see this trend or is it just some unknown factors that are making a difference? If after June 21 my power starts slowly dropping, and it has to, maybe I'll know better....Just thinking!~Comment
Follow the link. you should be able to find a system at your local area with similiar setup for comparison.
1.) Others probably see similar. It's more than just the length of the day.
2.) After array location, azimuth and elevation, some of the other, perhaps lesser, but by no means all of the particular factors influencing "average" daily array output: cloud cover, Daily total maximum possible irradiance which is f(date, solar geometry), array temp. as f(ambient temp., wind), atmospheric "clearness". Short example: Probably higher ave. irradiance on 06/21 in the plane of the array will increase output, but probably higher ave. temp. will lower output. Lots of other stuff at work as well - common local afternoon breeze for example.
3.) Min. and max. average output time of yr. is very variable, but I bet will often fall before or around the solstices. There will usually be 1 time of year (maybe for a couple of weeks or so) when max. output will be likely, and one time of year for a likely min. FWIW, as an example only, my max. ave. daily output seems to be ~~04/21-05/10 or so. Min. seems to be ~~11/15-12/01 or so. Every array will be different.
Also, check PVoutput.org. for locations near you.Comment
aren't having issues clouds or lessor effects, which have a huge effect here. Bruce RoeComment
Originally posted by inetdogI cannot resist asking whether those are effects which only apply to a leased system.Comment
Monitor
Another monitoring option which provides Web Access to your data is the EnviR by currentcost. I've been using one for a couple of years and it's simple but reliableComment
Note on pvoutput.org, to leverage the net calculations to back out actual household consumption from net, I had to make a small donation of about $10, good for one year to be recognized as a donor. That feature is fairly new, just showed up a few months ago before I started to use it, and for now requires donor status.Comment
