Rotating banners with links
Results 1 to 6 of 6
Thread: 3 phase electricity from solar panels
    Dec 2009
    3
    Default 3 phase electricity from solar panels
    Hi,
    im new to the solar energy game so please accept my apologies if i sound dumb.
    I was wondering, is there any way to convert the electricity i get from solar panels into 3 phase electricity.
    If so are there systems avaliable on huge scales so that i could power my whole factory, i have a 1.6 Mega Watt maximum demand.
    cheers
    5,960
    Xantrex mkes some big beasts: http://www.xantrex.com/web/id/254/p/1/pt/23/product.asp
    250KW is pretty big, but you will need a lot of solar to drive that. And a forklift to move it
    Montgomery Burns
    gear :
    Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV || || VEC1093 12V Charger | Maha C401 aa/aaa Charger | SureSine | Sunsaver MPPT 15A
    Dec 2009
    3
    thanks for that, i have acces to loads of space for solar paneling, i assume it is possible to convert to 3 phase energy, the grid must do it somehow
    5,960
    The Xantrex industrial 250KW inverters ARE 3 phase.
    GT 100 & 250 Grid Tie Solar Inverters - Three phase - 60 Hz models 480 Vac 301 A rms
    A couple of those running will put a dent in your pocketbook, and grid consumption !
    Transformers are also used to convert 1 to 3 phases, and back, but the power co just uses 3 phase generators.
    Montgomery Burns
    gear :
    Dec 2009
    3
    Thanks mike this has been a great help, if i need any more help i know where to come.
    thanks again
    5,960
    Glad to be able to help.
    Montgomery Burns
    gear :
