TRACER MPPT 3215RN Solar Charge Controller --- Review?
I've been using the Tracer 4215RN on my shed for over 12 months without any issues. I have 6, 190 watt panels and 170AH of batteries at 24 volts. Just running with some old truck batteries at this stage. System will be used for pumping water from a ground level tank to a header tank eventually.
Occasionally the system shuts itself down for no apparent reason. Simply a matter of switching off the battery and then switching it on again. Probably happened three times in 15 months.
Hope this helps
Rickey -
Hope this helps
RickeyComment
Just found it....
They show graphs that indicate 90%+ efficiency with solar input at Vmp=68V going to a 12V nominal battery, so I think that part is real.
High point of the whole manual, IMHO is were they tell you in detail to wire in an inline fuseholder on the battery and load connections, NOT insert any fuses, and then power on the CC and test it.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Not sure if this is what you're after http://www.epsolarpv.com/en/index.ph.../158/am_id/136 for the Tracer-3215RN?
RickeyComment
RickeySunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
With a listed maximum Voc of 150 volts and the capability to be used with either a 12 or 24 volt system, it has to at least have a somewhat functional DC to DC converter. But I have not found a full spec sheet for it online yet.
Just found it....
High point of the whole manual, IMHO is were they tell you in detail to wire in an inline fuseholder on the battery and load connections, NOT insert any fuses, and then power on the CC and test it.Comment
Hope this helps
Rickey
I already made my decision when rickeyh said it shut down 3 times in 15 months.
Thank you for your honest review... I had a gut feeling these have gremlins.
I cannot afford a shutdown/restart.
All the questioning of its MPPT capabilities just grinds this CC into the pavement for me.
I gotta step up the budget...
I'm shopping Blue Sky Energy.
I got my eye on this one >>> http://www.blueskyenergyinc.com/prod...i-hv-2512ix-hv
I'd go with a MorningStar if they had a 25-30A model with Night-Light control.[CENTER]SunLight @ Night[/CENTER]Comment
