Looking for critique of my solar plans for 22MLE
  • Naruto
    • Aug 2021
    • 25
    Hello all,
    I have already gotten some input from Howard in a previous thread concerning the connections between the solar panels and the charge controller, but now I am posting my "full" plan/schematic and would appreciate some of the more knowledgeable solar veterans to give it a once-over.
    On a previous trailer I installed 1 panel with a PWM controller and went straight to the lead-acid battery on the trailer tongue and did not alter any of the existing wiring. But this time I am going a little more in depth and will be making alterations to factory wiring too.
    We do not need a "full blown" setup like some of you full time boon-dockers have, but rather just enough to get us through a 3 day boon-docking trip. So we really have no need for much in the way of AC power, as we aren't looking to run the microwave or anything like that. I just want to have all the normal 12v DC functions of trailer working and possibly running the furnace at nights. If anything, I might add a small 800 watt inverter down the road if it ends up that we have power to spare. But right now I just want to get the DC part of the puzzle all worked out and done correctly.
    Yesterday I took out a few of the bolts and pulled down the underbelly chloroplast just far enough to see in there with a flashlight. I "think" I can see how the factory wiring is done, and how it feeds to the disconnect switch in the pass-thru. But I am still not 100% sure, and probably won't know until this Spring when I can fully drop the underbelly and have a good look. So it might end up being that some of my wiring plans back to the WFCO will need to be altered if I find things aren't run the way I think they are right now.
    Any and all suggestions and fault finding is most appreciated. You will not hurt my feelings [IMG]file:///C:%5CUsers%5Ca%5CAppData%5CLocal%5CTemp%5Cksohtml% 5Cwps6CF9.tmp.jpg[/IMG]
    And I apologize in advance for my lack of schematic drawing skills. Hopefully it is not too jumbled and confusing.
    Thanks
    The image seems unusable, it's pointing to a file on your hard drive, and the thumbnail is too blurry to see anything
