On a cold day - yes. But you may have trouble trying to Equalize the battery with it. A 24V FLA battery needs 30 - 32V for EQ. That's very close to the max the panel can produce.
That panel would work for sure with a cheap PWM controller and give you about 8 amps
With a really good MPPT controller, that will work down to 30V, you may get 9 amps output. (to do their power shifting, MPPT controllers need about 1.5 x peak battery voltage to work)
Sure you can run a 600w inverter, but remember, you have to be able to recharge in 48 hours, what the inverter consumed. That may mean more panels. And the inverter will consume a not-insignificant amount of power
OK I understand now. To use 1800 watts AC on my inverter, I need to pull 2100 watts from the battery at a little over 10% loss. So that would be DC loads plus 10 to 15% loss, plus a certain amount of amps per hour to run my inverter. On the 2000 watt inverter I mentioned, it pulls 12 watts per hour or 288 watts a day just to be turned on.
So may fix your flickering problem, but now you’d need a bigger battery and more panels than before.
