I want to make a small solar car capable of going up to 30mph with around 1500w max power draw. Using 4 sunpower flexible panels 170w each 30vmp and 5.84 imp. 6lbs x 4 =24lb total weight. Probably 52v battery. Will be using a bicycle trike frame to start out with
I was also looking at a 2s2p configuration to boost voltage to 60v so I can use a mid-nite solar KID Mppt ($300). is there a better MPPT to use. I like this one because it supports a DC load as well as battery charging.
I'm not even sure If I need an mppt? What would happen if I hooked up the solar panels directly to the battery AND motor controller at the SAME time? If the battery was full then the energy would go to the motor controller, but what happens when the battery is low and I'm going up a hill. That would be the worse case scenario.
https://www.youtube.com/watch?v=GAuVco35tzI is the video that got me thinking about this. skip to last 30 seconds.
