Heading into my second winter in a location that receives little to no sun for the next couple months. Today my Outback controller tells me only 12 amp hours gained from the sun. I'm off grid and will be relying on a 11kw yamaha diesel generator.
I see alot of very usefull info here on solar controller settings and it has been more than helpfull! Thank you all.
I have been running my generator 4 hours a day to replace my roughly 80 to 100 amp hours daily use. I have 8 rolls 6v batteries in series for a 48v bank. The settings I use for generator charging: Absorb = 60v, Float = 54v as per the manufacturer and absorb time 4 hours max.
I've been using a temp correct refractometer to keep my sg in check.
I'm trying to find a better balance between diesel useage and battery longevity. If I only charge to 90% in 2 hours my diesel useage goes way down, but my batteries will sulfate. If I go the full 4 hours on the generator my batteries charge nicely, but I use twice the fuel, it stinks, and is noisy more than I'm comfortable with. The generator is a constant 3500 rpm (I think) with no eco throttle or any way to produce less than 11,000 watts even during the final 10% charging stage. Maybe charging to 90% 6 days a week and up to 100% once a week would be the solution?
Any advice on how to set this up as efficiently as possible would be greatly appreciated! Thanks
