Greetings to all,
This is my first post and I have just started out playing around with solar panels and electricity in general. I have bought 2 identical panels from China and by measuring each one of them with a multi-meter I am receiving 0.4A and around 15-19 volt/each. If I connect them in serial I get in total almost 40 volts and 0.8A.
I know volts should increase but why does the amps increase in serial?
If I connect them in parallel which I really want, to increase amps but not the volts, my measurements are always 0.4 amps when in reality it should read 0.8 amps.
What am I doing wrong here?
I must say that I am new to multimeters also so maybe I am measuring it wrong or have connected wires wrong?
When testing serial I connected on of the + wires from one panel with the - on the other and made measurements on the other two cables.
When testing parallel I connected + with + and - with - . Is this correct?
Cheers to all
Cheers to all
