Haven't been on the form in a while, to see if anybody's testing the experts response to the claims of solar recently becoming one of the cheapest viable sources of power. And sorry in advance for any controversy I may be starting. Any opinions?
News claiming solar becoming one of the cheapest power sources
It really depends on the location of the power generation. Solar can be much cheaper than other power sources but you still have to figure in the daily availability percentage and what you will use to power your loads when the sun is not available.
Unfortunately most people fall for fake news or are easily led into believing anything if it sounds great. -
Some applications may well be cost effective at this time. Others may never be.
What you are looking at is a moving target with definitions that also change, usually depending on the agenda of the writer/speaker and their political/economic perspective.
Solar farms in the desert working with a high gov. subsidy may have a busbar post subsidy LOCE competitive with conventional power and if the POCO has a high cost rate structure may, it may make PV more cost competitive for distributed (residential) PV applications.
But without dragging off the public tit, renewables are usually less than the slam dunk the green mafia media and rose colored glasses wearing solar dreamers that glom off the solar ignorant would like us all to think and believe.
On the plus side, that means that utilities will now be installing a lot of PV in places like Saudi Arabia, Phoenix, Florida etc. That helps them because the power is close to synchronous with loads - on bright, hot, sunny days loads are high and generation is high. That means you can integrate a lot of solar with very little change to the power grid - and since it's so cheap, for little cost.
On the minus side, now you have higher ramp rates when the sun goes down for conventional sources of generation. When all that solar goes away right before the peak load part of the day (usually around 7pm) you have to spin up your conventional sources much faster than they are used to.
As solar gets built out, the problems of ramp rate, grid stabilization, peak shaving/peak shifting, demand response and curtailment will become bigger. These are problems that will cost money to solve - but will allow the addition of more (cheap) solar. So there's going to be a balance between getting that cheap power and paying for the problems it causes.Comment
While it is generating, utility-scale PV is now cheaper than most forms of power in sunny places.
As solar gets built out, the problems of ramp rate, grid stabilization, peak shaving/peak shifting, demand response and curtailment will become bigger. These are problems that will cost money to solve - but will allow the addition of more (cheap) solar. So there's going to be a balance between getting that cheap power and paying for the problems it causes.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
You recently reported on a battery conference. I just read about a larrge battery bank being installed in conjunction with a solar farm in California. Presumably that will reduce the high ramp rates required from other resources. In California we are already paying high rates for for the peaker plants that can ramp quickly.Comment
Once the initial investment is paid, you get a good 10 or 15 years of 6 hours of Free power (in decent locations) but then maintenance starts to spike, and the "cheap" goes away.
And those big "grid scale batteries" are good for about 10-30 minutes - long enough to spin up fossil plants.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
In my opinion the biggest risk of rate increases in California is not generation cost it is distribution costs. That is particularly true where PG&E is facing liability for poorly maintained wires starting fires.Last edited by Ampster; 06-18-2019, 01:27 PM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
I am afraid that most people will not be able to afford even cheap home energy storage which will put them in the dark if their POCO cuts power for any reason. There are way too many people living below poverty level now. Imagine how many will be in the dark if electricity can't be a guaranteed source.Comment
