Hello,
I've googled until I can't google anymore.
Hopefully someone on here knows this answer:
At what inverter temperature should the fans come on for an SB7000-US inverter? I just installed a DYI ground mount system with 36 230w panels/3 string system and today was the 1st day with
net metering installed. Was checking the inverter temperature parameter from the data stream (rs485). Is 140 degrees high? Ambient temp was about 75-80.
Plan on doing a fan test tomorrow.
Thanks for any input
Dan
Dan
