Okay need some help i have a solar panel and a wind turbine instaled with a inverter and 2 les batts, also the control pannel were all the wires go in the pannel the turbine etc bare with me as i dont no much about this sort of thing, the batts are charging but they have been used for a good few year, the lights im powering im changing the bulbs to LED which will total to 160 watt they have energy savers in at the min im not sure the wattage of them after invert power loss etc the pannel and the turbine will be creating 300w per hour with sunlight wind etc have i just not got enough power getting created or would you say the batts are done as i can leave them all day and they only last around 45 mins when turned on?
Power
How Large is your inverter ? 300W ? 1200W ? 3000W ? The larger the inverter, the faster it will drain the batteriesPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If you are saying things like "solar panel" my first guess is that you don't have enough generation and as a result have killed your batteries.
For more help:
1) Tell us how much power you use per day (in watt hours)
2) Tell us how much generation you have and where you are
3) Tell us what size your battery bank isComment
