Well New PV Sys is running prefect. So what's up,I need a Isolation Transformer and variac well sort of! I am building one with 12v battery+750W PMW Inverter+ DROK Motor Control Board AC 110V 4000W Adjustable Voltage Regulator SCR High Power Controller+ Volt meter+dummy load, I Can add voltage to untested equipment with out blowing up house and myself some of these outputs are 600V Cost me $20.00 for DROK had all the rest just hanging around. Tell what you think. By the way it works I can pull 50v ac to test with no problems.
Isolation Transformer and Variac sort of !!!
I think its gibberish. But if your house is not on fire, I guess it works.
What you list is a bunch of brand names, and I have no idea of the actual function of the stuff. No commas, so I can't tell if you have a motor control board for 4000w or a 4000w regulator or dummy load. SCR's will generate a whole bunch of electronic noise. And you can't possibly get 4000w from any normal household circuit
> Tell what you think
What you list is a bunch of brand names, and I have no idea of the actual function of the stuff. No commas, so I can't tell if you have a motor control board for 4000w or a 4000w regulator or dummy load. SCR's will generate a whole bunch of electronic noise. And you can't possibly get 4000w from any normal household circuitComment
For testing old radios, a series wired light bulb socket, with a 100w bulb is a winner. The bulb is you current limiter, have a couple bulbs to swap in, and when you are happy, flip a switch to bypass the bulb and apply full power.
Attached FilesPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I might apply B+ directly with a variable, current limiting supply, watching the A meter,
tubes cold while I turn it up.
Then I use the variac plugged into a watt meter. Bruce RoeComment
FuseSaver.jpgComment
Yup I just have a Profit problem with AliExpress there variacs average price is $10-20 bucks Resale here in U.S. is $50-$100 for cheap Chinese junk. My local University has electro-lab equipment auctions while i wait for one. This will do the job in repairing old Heathkit electronics. B+ on my page is better then B-anned. Its just fun utilizing old dust bin solar stuff.Last edited by Paul Land; 01-24-2019, 03:34 PM.Comment
There is a lot of tube gear still around here, that is all there was when I started. Plenty of
Heathkit, I make some effort to keep everything operational. One thing I do NOT like is all
those zip cords, messy and dangerous. So most get converted to IEC modules, which can
provide the safety ground, convenient removable cord, fuse, and even lighted switch in one
module. Here is an example where a really messy internal AC arrangement was entirely
cleaned up for this high quality, still useful, but ancient unit.
I also try to have a pilot light on everything, either red on the panel or LEDs into the
meters. If I turn off the lab light and see no pilot lights, I know everything is off.
With patience, I have gotten a lot of variable transformers off Evil Bay. Bruce Roe
90651.JPGLast edited by bcroe; 01-24-2019, 03:47 PM.Comment
