Announcement
No announcement yet.
Solaredge Inverter Limit Set Wrong
  • Filter
  • Solaredge Inverter Limit Set Wrong
    Breif overview 22;LG 310 Solaredge Inverter that had a communication board d damaged from nearby lightning strike, System maxes and clamps at 3500 watts.My installer denied a problem initially waiting to here back I think he was just lazy and didn't check array.Production was over 6k prior
    Solaredge screen says limit 3500 array always says 3480 and a straight line at 3500 if you look at daily production.So set wrong is my thought am I right?
  • #2
    Hope this upload works.
    • #3
      And Inverter
      • #4
        Correct. Replacement board is not programmed correctly or is wrong model. You can give your installer a 2nd chance, but I'd just contact SolarEdge, They can likely see the issue / push updated software/firmware remotely. There have been other similar issues on the board in the past year or so.
