I am looking to buy a new chainsaw. In my backyard there are some bad trees on it and I would like to cut them and plant new ones. Does anyone have any experience with chainsaws and can give some tips?
New chainsaw
Assuming you mean a chainsaw, without the right training and equipment cutting trees is very hazardous. Loggers have one of the highest workman's comp rates for a reason. If you are considering buying a saw make sure you buy a set of Kevlar chainsaw chaps and a cutting helmet. There rarely is a minor accident with a chainsaw, usually a grievous injury and on occasion death. A quick search for chainsaw injury images is pretty sobering. Ideally take a course and get certified to use one correctly.
If you do decide to buy a saw, there are two types, throwaway homeowner saws or pro saws. A pro saw can become a throwaway if you don't treat them right, A homeowner saw will get the job done but don't expect a long life. With the advent of ethanol gas, many saws are worthless if they sit for several months with gas in them as the ethanol gums up the carb. You do need to learn to sharpen a chain or plan on buying several and get used to paying someone to do it for you. A dull chain makes a saw even more dangerous and if you get the tip in the dirt (which is really easy to do) it gets dull quick.
The other big aspect is the actual cutting. Trees weigh a lot and if you don't know how to cut them they can kill or seriously injure you plus do a lot of property damage.
They are great tools, I have used them for years but I am careful and aware of my limitations, those who don't including the morons on the various cable TV shows end up getting hurt. Remember just because some moron on video or TV show gets away with stupid stuff doesn't mean you can. Even with the right gear I have been hit on my helmet on occasion by dead branches that would most likely been serious if I didn't have one on. I have managed to avoid catching my chainsaw chaps with a chain but know many folks with a old pair hanging on the wall with a big slash across them. $100 bucks for new pair is heck of a lot cheaper then a trip to the hospital.
Realistically if you aren't planning to use a saw long term, pay someone to do it. I heat with wood and have a wood lot so I use mine every few months. -
Ok whoops, i was doing a spelling mistake oskars post and then seen you already replied, sorry about that....carry on, welcome oskarComment
If you are just looking to cut a few trees, one of the homeowner grade saws will do the job just fine. I have a homeline that my dad has had for 15+ years. I bought him a new Husquavarna a couple years ago, so the homeline became mine. With a sharp chain, just about any saw will cut well.
Depending on how much you need to cut, you may also want to look at a battery saw. Some of the new high power battery saws are supposed to be really close competition to smaller gas saws.Comment
Get some training and experience first. If you go out and buy a good Stihl Chainsaw and try to cut down some trees with no experience is not going to end well for you. Anything from cutting of an appendage, to fatal injury.MSEE, PEComment
I own a Stihl MS 250 and it is a work horse. But you have to pay attention or it will kick back and bite you.Comment
Why would someone join this forum and in their very first post only ask about chainsaws?Dave W. Gilbert AZ
6.63kW grid-tie ownerComment
Originally posted by azdaveWhy would someone join this forum and in their very first post only ask about chainsaws?Comment
For the small stuff, I use a forestry 8" blade in the battery op Sawsall. no fumesPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Ego or Milwaukee. They will make you wonder why anyone would want to use a two cycle engine anymoreComment
The safety issue is real. Beyond that, it is just another engine to maintain. If you are in the solar game you probably already have a generator to maintain along with at least one car/truck. The thing about maintaining a chainsaw is most homeowners only use one on a rare occasion. How many people use a product like TruFuel or buy recreational (no alcohol) gas and mix it with oil, then completely drain the saw when done and lubricate it before it gets put back in storage? Even then, fuel lines and primer bulbs have a way of decomposing and only show that they are bad the next time you go to use the saw. I agree with many others here, pay someone else to cut the trees. Make sure they have insurance. Not just for themselves, but in case they drop a tree on someone else or damage someone else's property.Comment
Both my 16 & 34" saws are 2 cycle, and I use aviation gas in them. best stuffPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
