Hi all, after system was installed I got up on the roof to inspect panels found them to be covered in boot prints and finger prints also smeared silicon. Are panels rigid enough to withstand people standing on them? They are 275w seraphim's. Qld. I have withheld payment untill panels are cleaned.
New install with boot prints on panels
I guess they've had silicon on there hands while installing panels... Panels are on 3 areas of the roof. Should panels be stood on?Comment
You can stand on them but should be avoided unless last resort as you get micro fracture in the cells.
there should be no reason to have silicone when installing pv modules, and leaving it on the modules is ridiculousLast edited by ButchDeal; 08-08-2018, 09:20 AM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Are they strong enough to withstand the force of someone walking on them? Yes, they have to withstand high snow and wind loads.
Should anyone be walking on them? Absolutely not. Several studies have shown that the high weight concentrations on panels can lead to micro cracks in the silicon which causes much more rapid degradation.
I would be calling the installer up and telling them to replace all of the panels, and install them correctly.
Also, they smeared silicone, not silicon. Silicone is a liquid rubber. Silicon is what the panels are made of.Comment
Originally posted by emartin00 View PostAre they strong enough to withstand the force of someone walking on them? Yes, they have to withstand high snow and wind loads..
Panels are not designed to be walked/crawled on. STAY OFF.Comment
Thanks emartin00, yes silicone. I guess there is a out put/circuit test for each panel which will need to be done, ill call head office with my concerns as I've been dealing with the salesman.Comment
Originally posted by Eqnx33 View PostThanks emartin00, yes silicone. I guess there is a out put/circuit test for each panel which will need to be done, ill call head office with my concerns as I've been dealing with the salesman.
Originally posted by ButchDeal View Post
they very likely will test fine now but will have a much higher likely hood of premature failure due to micro-fractures in the cells.Comment
Thanks for the info, still cant belive theyve walked all over them! They have a 10 year warranty but i have informed Seraphim (manufacturer) of the issue after install.Comment
If you push the issue with the installer, it would be good to have pictures of the footprints and an email from the panel manufacturer stating that they could be damaged if walked on. That would be hard to argue with.Comment
