I have a samlex inverter/charger evo 1224. Its a 1200 watt 24v inverter. (sunking got me out of a 12v box) I will be using this as an UPS for an aquarium pump and to run one bedroom, maybe a fridge, during a power outage until I pull out a generator. I will be supplying it with 4 Deka 230ah 6V in series. According to the specs, it has a built in charger of 40 Amps and also accepts an external charging source ( solar, gen, etc.) Is 40 amps enough during Bulk for 230ah 24v bank? I know the 10% rule but the 24v is throwing me off. Should I attach another charger to the ext. charge inputs? Thanks for your input.
http://www.samlexamerica.com/documen...Sheet-0118.pdf
