I have a few water pounds I want to use water pumps to circulate the water around and I was wanting to use solar to run them. The idea is to run panels
to operate a 50-100w pump. I don't care to use any batteries just to go from inverter to the pump and whatever the hours I get from it per day is what it is. So the
question is what watt panel do I need to run a 50-100 watt pump direct from the panel/inverter?
