One thing to notice is the roundness of the curve. I would think that if i were getting clipped that the top would be very flat.
Watt Hour / Output
Originally posted by fatcat View PostOne thing to notice is the roundness of the curve. I would think that if i were getting clipped that the top would be very flat.
Solar production is not the same every day...
Also you have micro inverters your clipping is at the PV module level and since you have multiple Azimuths it will be harder to see at the array level.
look at the graph for individual PV modules for clipping issues. with micro inverters.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Originally posted by Sunking View Post
I did say roughly right?
And not being a fan of pyrrhic victories for either one of us, or at least not for me, especially believing you & I have agreed (at least tacitly or informally) to disagree about the worth of the term "sun-hours", I won't rant about it's use. No gain there.
However, to clarify something, at least in my mind, but maybe others as well, since more than one definition of the term "sun-hour" seems to be available - I know of three in some use, all of them different and as best as I can determine all being about equally ill-defined - your post seems to be defining a sun hour in yet another way: A "sun-hour" is how long it takes an array to produce the number of kWh that's numerically equal to its STC rating. That is, you seem to be saying a 14.88 kW array that somehow has exposure to 3 "sun-hours" will have <= 44.6 kWh output for that day. The "<=" being the "roughly" part.
The last word is yours if you want it.
Respectfully,
Originally posted by J.P.M. View Post
Yea, you most certainly did. No argument there. Read it myself. Right there in black & white without ambiguity. As long as you're being sarcastic, thank you for the rhetorical question to what I meant as a serious post.
MSEE, PEComment
Originally posted by Sunking View Postwho needs injuneers complicating things with minor details.Comment
