Mix Panel for off grid battery system
There is a somewhat broad operating curve, allowing this. Bruce Roe
WWWComment
If a panel is operated 1% below its MPPT voltage, you don't lose a whole percent of power, because
as the voltage drops, the current increases. Same thing going the other way. So I suggest that for
small differences, the % power loss is LESS than the % voltage difference. But I'm not going to run the
experiment to prove/disprove it. Bruce RoeComment
Thank you all for your reply, please let me know what design below produce the most power (wattage)?
Please note, there is 2.6V different between the 2 panel. Both panel are different manufacture.
Attached FilesComment
Series wiring the panels will cause the current of the larger panel to be limited to the current of the smaller panel. NOT GOOD
Parallel wiring the two will not produce voltage high enough to get the benefits of the MPPT controller.
The only way I see to get the best performance would be to parallel wire the panels and configure the batteries in a 12 volt bank.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Originally posted by SupraLance View Post
1st, a single 60cell panel should never be used with a 24v system, it doesn't produce enough voltage, and that is why your issues. You need another matching 60cell to use this in series through an mppt controller, or you need to use it for a 12v system.- Would you please explain to me why the 60cell panel can't used with 24V? I have been using this panel for the last 4 years to charge my 24V battery but I don't see anything wrong with it. On my cheap MPPT charge controller, I set my cutoff voltage at 27.2V and power off load at 24V. Some time the MPPT display 26.2V @ 10.2A (on a sunny day with cool temp at around 65-70F)
If you put the panels in series, the voltage will add and you will be good there (IF your controller is truly MPPT), but the amperage will be pulled down to match reducing the watts. So both panels would end up producing at about 8a, one @30v and one @38v, for a combined 68v & about 550w. BUT more likely your controller is actually PWM and can't do this, and that much of an amperage mismatch isn't considered safe. Would not recommend this either.- What is the risk for amperage mismatch?
- I thought when putting 2 panel in series, the voltage will increase while current is the same which I will get 4.9A output for 68V which equal to 333W, am I right?
- How do I know if the CC is real MPPT, fake MPPT or PWM?
With an actual MPPT controller, the two 72cell panels (175w & 360w) could be ran in parallel, although this would force them to operate at the lower voltage of the 175w panel. This would only cost you about 10w, producing 525w (at STC). But then your left with the 60cell panel for the other system, and it really needs a 60cell buddy to be any use at 24v.- Please explain on how do I get 525W when connect two 72cell panels (172W & 360W) in parallel?
- Does voltage different between 2 panel (35.8V vs 38.4v) matter?
Suntech 250w + LG 360w in series, 30.7v@8.1a + 38v@9.8a, will pull the 38v panel down to the roughly 8a of the other panel, resulting in 38v@8a = 304w from your 360w panel. 304w + 250w = 550w [This is rough math and is rounded because it isn't precise anyway. What actually happens is far more complex, but this gives you a general idea of what to expect.]
You mention 4.9a, so you must be calculating the BP 175w panel in series with the LG 360w. 35.8v@4.9a + 38v@9.8a, will pull the 38v panel down to 4.9a but leave the volts alone, resulting in 38v x 4.9a=186w from your 360w panel. 175w + 186w = 361w
In parallel works the other way. 35.8v@4.9a + 38v@9.8a, will pull the 38v panel down to 35.8v but leave the amps alone, resulting in 35.8v x 9.8a=350w from your 360w panel. 175w + 350w = 525w
As for real vs fake mppt, lots of good info on youtube about that, but the cheapest confirmed real mppt I'm aware of is the EPever.
Littleharbor is right, and this is a serious issue. A real MPPT requires higher input voltage than output voltage. Your better off with separate pwm controller on each 72cell panel, and only using mppt if you can series similar amperage 60cell or 72cell panels.Last edited by SupraLance; 04-07-2018, 02:05 AM.Comment
