Has anyone done the math on this to see how big an impact it'll make?
https://pv-magazine-usa.com/2017/08/...-tou-peak-time
I'm on EV-TOU2 rates so I currently "earn" almost 49 cents per kWh between Noon and 6pm. Other generation currently "earns" 24 cents per kWh. For the last 2 years every bill I've received has been for the minim charge or roughly $10 per month and I have had approx $200 in unused credit at the end of the year that is lost. It looks like this is going to change...massively.
Approximately 66% of my total generation is between noon-6pm.
Approximately 12% of my total generation is between 4pm-9pm
Using the Summer Rates...so worse case scenario...54% of my generation will drop from "earning" me 49 cents a kWh to 24 cents per KWh...GULP!
With 9000 kWh generated in 2016 the cost "increase" for me will be about .54 X 9000 X .25 = $1215 or $100 per month!
The difference is not as marked for Winter due to Peak and Off-Peak TOU rates being only 5 cents apart so I can probably halve the above number...$50 a month.
Does that math look right?
