Somebody want to talk me thru or out of this?
  • yetavon
    • May 2017
    • 5
    The situation is we are planning/building our retirement home. We have bought a few acres, an old house that is occupied and will remain rented, well and septic. The plan is to build a "shop", and live in a camper. The shop will get a bathroom/Kitchen at some point. I can retire in 3 years, wife has 10 more till full retirement, but may go early and then this will just become a drop in spot/storage area as we take off and travel. So I get the bright idea of solar setup for the camper, why not carry it on over to the shop to?
    I'm thinking of 12 volt LED lighting and appliances in the shop, some 110 circuit's for other items, like building a chest refrigerator. 24 volt battery bank, pure sine wave inverter,
    Got an old 6x12 trailer for a panel mount base so I can adjust for seasonal changes, on a ridge top, so a wind turbine could also be added. We already have 2 generators, 5000K Onan from and old camper, and a 3100 champion inverter gen for backup as needed. Sound crazy or what?
    Kill-a-watt meter on its way to start figuring numbers....
    • 14921
    See my response to your first post.
    Take what you want. Leave the rest.
      • 5198
      Batteries left unattended have a very poor survival rate. Take them with you on your travels. How
      about an RV extension cord from the house to the trailer? Bruce Roe
      • Logan5
        • Feb 2013
        • 484
        Have a pole and meter installed for the shop by the PoCo. forget batteries, forget off grid. If you still want solar have a grid tied system installed. If you plan for solar before you build, you can more precisely position your building to take advantage of the pitch of the roof. If you still insist on back up power get a generator.
        • yetavon
          • May 2017
          • 5
          JMP ...I did...thanks....
          Bcroe... theres 220 to the well on 10 ga wire, 55 ft hand dug well with a 3/4 HP submersible pump. Got some 8Ga wire and considering replacing the wire to the pump and add a small panel there to add a 30Amp receptacle for the camper. The big issue is there is only a 100 amp feed to the house to start.
            • 14921
            You are most welcome.
            • yetavon
              • May 2017
              • 5
              Originally posted by Logan5
              Have a pole and meter installed for the shop by the PoCo..
              We had one there for the MH years ago....someone cut it down and took it....was quite ill when I discovered that....
                ....The big issue is there is only a 100 amp feed to the house to start.
                That's 10x more power than you would have with a moderately large PV setup.
                Consider a medium solar setup to be about the same as a 5A utility feed.
