This is a bit parochial, but for those in San Diego county who may want to know what their array might put out on what's close to a standard clear day around here for a time of the year when array output is high due to more perpendicular incidence angles of solar radiation, today, 04/29/2017 was about as standard a day in terms of what might be expected for a clear day's irradiance as is likely to happen.
Using something called the HDKR model of clear sky irradiance, today's modeled day long global horizontal insolation at my location in zip 92026 was ~ 7,794 W/m^2 for the total day. The Davis instrument that records horizontal insolation about 4 ft. north of my array recorded 7,735 W/m^2 for the day, or ~ 7,735/7,794 = .992 of a "standard" clear atmosphere's insolation for this date. Using another common clear sky model - the "Bird' model (after Richard E. Bird) - the modeled clear sky daylong horizontal insolation comes up 7,825 W/m^2. The numbers for both models are corrected for elevation above sea level and barometric pressure. The Bird approx. is also corrected for estimated precipitable water vapor in the atmos. as f(dew point) which may be one reason why it gave a bit higher daylong total, this being a rather dry day w/ dew points of ~ 20 F.- 30 F. at my location, about 20 miles inland and ~ 1,400 ft. above sea level. The Davis numbers are corrected for sensor temp. The Davis sensor is 9 months into it's 2 yr. calibration cycle.
This time of year in this area is one of two times/yr. when a lot of arrays have their minimum solar incidence angles (the other time being early/mid Aug.). If an array is mostly south facing and tilted something like 20 deg. as is somewhat common around here, the angle of incidence of beam radiation will probably be within ~ 5 or so deg., +/- some of zero around solar noon. Solar noon is about 12:45 or so P.D.T. this time of year in San Diego.
So, if it's sunny and clear (and no clouds) around 12:45 P.D.T for the next few days as expected, and your array is mostly south facing at ~ 20 deg. tilt (as many around here are), check your array's instantaneous output at about 12:15 - 1:15 P.D.T.or so. and you'll get a decent if still ballpark approx. of you array's max. instantaneous output, particularly if the weather is on the cool side and/or it's a bit windy. I've found it a nice number to have around.
