I just noticed the signature line has vanished from the bottom of our postings. Not sure why it was always so limited that you could barely describe a simple system using abbreviations but apparently it seems signatures aren't even wanted here. I've always thought they are helpful when members are discussing their systems, be they on, or off grid. Any explanations???
Signature line?
The same signatures are still there. You just have to turn them on to see them. Go to "User Settings", "Account" tab.CS6P-260P/SE3000 - http://tiny.cc/ed5ozx -
And just like that, there they are. Must have been a glitch.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
When you initially complete a post, the .sig is not present, but it will be for all future page loadsPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
A ha... Thanks. That's what appeared to be what I was seeing.
