Inverter (small)
  • RockyinNM
    • Oct 2016
    • 14
    Inverter (small)
    OK, so I'm on the grid, but have solar water well, and solar hot water, (evacuated tubes)-
    So this is what I would like to do, the solar hot water runs when there's daylight--it has a .95 amp circulating pump that is 115v--I would like to install a 12v solar panel on roof, and feed it directly to a (small) inverter to run the 115v AC circ. pump. No batteries needed!
    Any ideas on a inverter that can tie directly to the solar panel, and run the pump.
    Thanks, Rocky in NM
    36 evacuated tube, drain back solar hot water
    • 14925
    Thanks, Rocky in NM
    Unless it's for a hobby kind of reason, I'd suggest keeping the pump for the solar hot water system on grid power. Less hassle.
    • RockyinNM
      • Oct 2016
      • 14
      We have many outages in this area---1 to 3 @ month, lasting 2 to 7 hrs, it would be nice to make hot water, without firing up the generator.
      Just trying to ck out my options.
      thanks
        Yes batteries are required. Very simple system design; 0.95 amps x 115 volt x 14 hours = 1.53 Kwh
        That requires:
        Panel Watts = 850 watts
        12 volt Battery Capacity = 640 AH
        MPPT Charge Controller = 65 Amps
        Inverter = 200 watts.
        Should not cost a penny more than $3200, with roughly a $1500 battery you replace every few years.
        Have a nice day.
          • 14925
          thanks
          Understood. I lived in NM for a few yrs. Saw many thermosiphon batch heaters. PV pumping can work. 1st pumped DHW system I designed had DC pump and a small panel. Scrapped the pump & went to 120 V pump after about a yr. of fooling around. Maybe things are better now, but back in the day, a lot of such systems were sort of mickey mouse. Some approx. version of flow proportional to irradiance was a nice concept, but proved not worth the price in terms of initial price vs. hassle or potential lost production to me.
            • 15125
            Thanks, Rocky in NM
            Sorry. You really can't connect a pv panel directly to an inverter to run an AC load. You will need batteries and a charger or a special DC voltage pump that is run through a controller with a solar panel connected to it. Those are not cheap.
            • organic farmer
              • Dec 2013
              • 644
              thanks
              Greetings, I live in Maine. I also have grid power, and the grid here is very much like you describe in your state.
              • RockyinNM
                • Oct 2016
                • 14
                OK, I get it! Just thought I would ask--I know I (probably) could change circ. motor out to a 12v--would that allow me to go direct to solar panel??
                • Wy_White_Wolf
                  • Oct 2011
                  • 1179
                  If you wish to run solar direct you need to forget the AC pump and go with one that is capable of running in that mode.
                  WWW
                    • 5198
                    What is the gph and head pressure required of the pump? I would elect to use a 12VDC pump connected to
                    a standby battery, which is kept at float voltage by an AC charger large enough to run the pump when it comes
                    on. So the battery would have a very long life, essentially in float all the time except for outages. The panels
                    really aren't the best approach to this solution. You might be able to use a battery already there, such as a
                    stored vehicle or gen set.
                    I have a 12VDC pump that runs on 4W, but only at no head. Bruce Roe
                    • PNPmacnab
                      • Nov 2016
                      • 425
                      I'm curious as to what this system is, domestic water or hear? Is it a closed loop and under what conditions does it run, on a timer or thermostat or just all the time. If the sun is low level can it be off for a time?
                      • RockyinNM
                        • Oct 2016
                        • 14
                        Yes, residential--36 evacuated tube, 120 gal.solar water heater, with 1500 watt. elec. back up. It is a closed loop drainback. It is run with a thermostat that has a 13 degree difference from the collector-from the tank temp. It has a small 115v ..95 amp circ.pump.
                        If it was just me here, it would supply all my hot water needs, but TW (the wife) draws a big bath every evening.
