Happy New year to all in this forum. my question is i buy delta lightning arrestor LA302R to use in my schneider sw2524 system in especific schneider ac breaker box.and i not expert in electrical connection.i need were conect the cables. the cable white on the AC GND BUS Bus or N BUS?. the black cable to L1 and L2.? any idea thaks for your help.
Delta Lightning Arrestors LA302R on my schneider conext system
I don't know what the data sheet/instruction sheet with the Delta says - but that's what I suggest you use.
Another thought, my Delta's are outdoors, on the PV array poles, protecting the DC lines before they enter the building, I want to keep the lightning OUTSIDE, not bring it indoors just to send it back out to ground.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Well if you have to ask, you are better off hiring someone who knows what they are doing. As Mike said anywhere inside and/or improperly terminated will have the exact opposite result you want inviting lightning to come right on in put it feet upon table, and hand out with you. If properly located and connected does little to nothing.Last edited by Sunking; 12-29-2016, 11:42 AM.MSEE, PEComment
Originally posted by Sunking View PostWell if you have to ask, you are better off hiring someone who knows what they are doing. As Mike said anywhere inside and/or improperly terminated will have the exact opposite result you want inviting lightning to come right on in put it feet upon table, and hand out with you. If properly located and connected does little to nothing.
It also shows a DC arrestor (2 wire + ground) wired to a combiner box between the panels and inverter which is more than likely outside..Last edited by SunEagle; 12-29-2016, 11:58 AM.Comment
Originally posted by SunEagle View Post
It is interesting that the manufacturer, Delta provides some detail showing their AC lightning arrestor (3 wire) being mounted at the load center or circuit breaker panel which is usually inside a building..
You, myself, and even a Sparky worth his salt knows that is BS, illegal, extremely dangerous, and can render the CNC Machine useless. If you think CNC is bad, TVSS manufactures are even more clueless at times as I think is the case here. Sadly the subject is very misunderstood and even some engineers really do not understand. It is not something taught in school or a book. Like how to make and save money, there is no book or taught in school. Well there is, I wrote a couple on Power Protection Engineering, but you have to be a club member to get a copy or pay to go to a application lecture to IEEE.
MSEE, PEComment
Well SE you have been in this biz as long as I have, and we know just because you mancfacture something does not mean they know what they are doing. How many times have you seen a manufacture spec of CNC Machines that require the user to install an Isolated Ground Rod to make the CNC work properly?
What I was saying is that the arrestor manufacturer shows where to install their AC arrestor and goes on to make someone feel that is ok.
I find that both interesting and very disturbing.Comment
