Announcement
No announcement yet.
Salvage Panel Glass
  • Filter
  • Salvage Panel Glass
    Does anyone know of a solvent that would dissolve cured EVA, so I can reuse the glass for a new panel. Acetone works....but is extremely slow.
    Thanks for any help you can give!
  • #2
    Try adding a lit match to the mix. That should speed things up a bit. Sorry, just kidding. I couldn't help it. You might try MEK or Denatured alcohol. And be careful with any solvents use outdoors and keep away from sparks or open flame.
    • #3
      You also might want to wear a mask or something to protect your lungs.
      • #4
        You could just buy my blank tempered glass, already framed in aluminum and with terminations and spacers in place. I have maybe
        10 left over from my DIY experiments, but pretty heavy, at 61084. Bruce Roe
        • #5
          Is all this to save money or for experiment/educational/hobby purposes ? If to save money, it's most likely an exercise in futility.
