Renovating a paned with shattered glass.
  • sbkenn
    • Jun 2016
    • 5
    Hi. Does anyone know of a solvent which will soften the adhesive used to attach an array to it's glass, without damaging the array ? I have two 200W Kyocera panels that got damaged in a storm. Both are electrically fine, but obviously no longer weatherproof.
    Acetone is pretty good stuff, but it may take a large bag for the panel, a couple gallons of it, and then you have to make a new laminate up with EVA.
    He's Dead Jim.
      • 5198
      I have measured semiconductors after the seal failed, and they seemed fine. But checked a year or so later, they were developing
      serious leakage. I threw them out. Bruce Roe
      • peakbagger
        • Jun 2010
        • 1561
        If you are doing this as a hobby or for curiosity then feel free to spend the time. The reality is the time and effort will be rewarded with failed panels sooner not later. Spend you time watching Ebay for new panels of the same model so you can swap them out with something that will last long term.
        • sbkenn
          • Jun 2016
          • 5
          The panel is a 200W Kyocera one, costing about
          • sbkenn
            • Jun 2016
            • 5
            Damnit ! My post keeps getting truncated !
            • Six4KilowWatt
              • Feb 2017
              • 41
              Call a glass shop, or other place that might have plexiglass...then get a tube of Sikka Flex adhesive...bead it up around the frame clamp it down, it's not ideal, but that sikkaflex is good adhesive...the stuff will stay put for years.
              Or just get a new panel.
                • 14925
                The plex will cloud/discolor in the sun and also from wind fatigue, and also probably increase the panel temps. for a couple of reasons. Not sure of the vapor permeability of that adhesive, but if it isn't high, it'll allow H2O vapor ingress in maybe an unacceptably high rate. If you want to fool around for the sake of learning stuff or having fun, go for it. If you want a functioning panel, get a new one.
                • sbkenn
                  • Jun 2016
                  • 5
                  Plexiglass aka Acrylic, even the type that is coated with a UV barrier, will acquire a colour withing 10 years, much less in hotter countries/states. Ditto, polycarbonate. Plastics/polymers, of any kind, just don't like UV. As for Sikaflex, there are a lot of products from SIKA that MIGHT work. I have asked them to recommend one.
