I came across a system in my area with a problem that they were unable to solve.
It is the system with the coil passing through the hot water cylinder, transfering heat
to the water in the coil passing through the hot water cylinder.
The cylinder and tubes are vented to the atmosphere.The system was installed by the supplier,
so one would presume they have done it correctly.
The coil that passes through the cylinder and then becomes the hot supply pipe has a T piece on the
pipe with a T&P safety valve fitted to the T after it exits the cylinder.
This valve is running and wasting most of the hot water, when replaced it makes no differance.
I cannot understand why there is a T&P safety valve on the hot line.
What should there be on the hot outlet, hi tony I'm sure you will know.
Thanks Hamish
Thanks Hamish
