I just got my new PV system up and running. SolarEdge SE5000H inverter. I attached a z-wave Aeon Tech power monitor to the AC wires coming from inverter to the main circuit panel just to double check how much power it is producing. The odd thing is that all night long, it CONSUMES 96W of power! Do SolarEdge inverters really vampire THAT much power? If so, that is almost 10% wastage of the 26 KW hrs or so that my system produces each day (24 hrs x 100W = 2.4 KW hrs of wasted energy). Specs say about 2W nighttime draw, but I am definitely measuring 94W nighttime draw.
Could this be an issue with how I am measuring this? I have one clamp on each live AC wire (L1 and L2) going between the SE inverter and the power panel to my house. Each clamp measures about 0.38 Amps. At 122V, that is about 47W for each wire. So added, that is 94W. Am I missing something?
EDIT ################################################## ##################
I resolved this issue using the method recommended by @FFE and @ButchDeal (turn all power in house off, and turn on circuits one by one to see power usage on my digital PGE meter). It turns out the SE5000 draws pretty much exactly what Solaredge says: 2.5W. It appears the Aeon Labs z-wave Home Energy Monitor (HEM v1) was giving very false readings. I just finishing installing a Wattnode Modbus energy meter which again confirmed the low 2.5W draw of the SE5000 when in sleep mode. Apologies for creating unnecessary confusion.
