  • blueman2
    • Sep 2019
    • 98
    Can I take control of owned system installed by dealer?
    I was going to do my own install, but ended up going with a local installer. LG335 panels with SolarEdge SE5000H (new one, no LCD display). I own the system. Will I be able to take control of the system using SetApp and be able to change configuration in the future (e.g. add additional panels myself if needed)? Or does SolarEdge somehow lock the owner out of the system config area? I asked my installer, but they were not really sure. They said they think once they register the serial number, it is permanently locked to them as the intaller and no one else can change config or add panels. That seemed odd, especially if the installer goes out of business in the future.
    • 3649
    You own the system and you can do anything you want. Your installer would have to let you take over configuring the system and should probably tell you if their warranty would be voided by anything you do. You would have to email SolarEdge and get an installer account to be able to configure the system. The access is by serial number and that is why you would have to have the installer allow the transfer of that serial number to the new account that you would have to start with SolarEdge.
    I had the opposite scenario. I Installed a system myself and got the installer login from SolarEdge. Then I had an installer put in another system at another location. but I registered the serial number on my account. That worked until the installer got the Permission to Operate and then I had to go to a new login to to view the system and I can't configure it. I have no need to configure because I don't want to mess with the warranty.
    • blueman2
      • Sep 2019
      • 98
      Warranty. Good point. Forgot about that.
        • 3802
        It is not permanently locked. You can creat an installer account and reregister the same serial number the layout will be lost though unless you write it down and reenter it.
        • blueman2
          • Sep 2019
          • 98
          Thanks ButchDeal and Ampster ! I already have an installer account since I was planning my own install, so that part is done. I will ask the installer if they are OK with me moving it over to my account. But I certainly understand that they might not support the warranty if I start adding my own panels. Not a big deal to me as I would normally go back to the hardware vendor myself anyway. I will just wait about 6 months to make sure all is working well with their install (such as any roof leaks!)
          Again, thanks for the great advice.
            • 3649
            I have a similar situation. The system was on my account but after the PTO the installer put it on their account. I tried reregistering it on my account but got an error message. I will probably have to ask the installer permission. If I do that I'm going to mak a copy of the Optimixer layout.
            • Six4KilowWatt
              • Feb 2017
              • 41
              Shoulda went Enphase That's all there is to it, better engineering, better reliability and more technologically sound. Smart grid, off grid...it's coming IQ8 is the real deal.
                • 3649
                I have a few IQ7s on some used 96 cell Sunpower panels. I also have some old Enphase M215 systems an a couple of roofs, two SolarEdge systems and a hybrid inverter running more used Sunpower panels. They are all the best. Opinions vary and needs vary. The best system is the one anyone has on their roof today. I think the Dalai Lama said the same thing about religion or philosophy.
                Last edited by Ampster; 09-27-2019, 11:27 PM. Reason: To correct description of IQ inverters.
                  • 15125
                  Originally posted by Ampster
                  I have a few IQ8s on some used 96 cell Sunpower panels. I also have some old Enphase M215 systems an a couple of roofs, two SolarEdge systems and a hybrid inverter running more used Sunpower panels. They are all the best. Opinions vary and needs vary. The best system is the one anyone has on their roof today. I think the Dalhi Lama said the same thing about religion or philosophy.
                  How did you acquire IQ8's? They aren't supposed to be unavailable in the US until later this year.
                    • 3649
                    I may have been confused, I think I have IQ7-96 inverters. They changed the model number from IQ7-plus to IQ7-96xx. I can't keep track of the iterations. I will change my post. Thanks for the tip. I hope that did not detract from the point of my post, which was that choices are more about what works for the user. We are fortunate to have a lot of good choices. Knowing which choice is best depends a lot on the situation of a particular install. NEC rules about Rapid Shut Down have made the economics more complicated.
                      With all the mistakes their marketing and engineering made already, I'm not sure I am trusting them to do better, that's going to take "proof", not your opinion .
                        • 15125
                        Thanks for the clarification. I was approached by a solar installer and they were excited about the IQ8 but also disappointed because it was not available yet. Based on what they said the IQ8 works like a hybrid inverter and allow a solar pv system to generate even though the grid was down.
                        Unfortunately the system they were proposing was still around $2.60/watt after all rebates which would put it in the 14 year payback area for me.
                        • blueman2
                          • Sep 2019
                          • 98
                          Well, I finally got my system installed and received PTO. I have an admin account with SolarEdge, but when I try to register my inverter I get an error message saying the inverter is already in use by another account. My installer said they know of no way to release the serial number, so I am out of luck in terms of being able to have full control of my system?
                            • 3649
                            That sounds like BS. I had my system on my account until the installer took it over. I wasn't asked for permission so they must have got SolarEdge to release it. Probably not hard for the installer to do because they purchased the inverter from SolarEdge or a distributor.
