  • Filter
  • Solar panel missing cable.
    Hello, new to the solar game.
    I bought a 100w panel at auction. When I opened the box I noticed that the cable from the connection box was missing.
    Will any MC4 cable work with ring connectors attached?
  • #2
    Make and Model of panel may be of help.
    • #3
      Perhaps someone took advantage. I would pry the terminal cover off and hopefully find
      some bypass diodes. I'd connect a pair of leads to each diode in turn, and run them to
      an ammeter under good sun to see if each section has reasonable short circuit. If good,
      you can attach your missing lead there. Bruce Roe
