  • Filter
  • #46
    Originally posted by Emorales View Post
    What determines what rate fuse to use
    The wire size, if you have a 10ga wire, it nearly always needs 30A overcurrent protection. NEC Ampacity tables list wire, insulation and amp rating
    https://lugsdirect.com/WireCurrentAm...ble-301-16.htm scroll down to the chart
    • #47
      So with a 50A 150v max Mppt.
      What is the maximum combination (series/parallel) of panels 260W I can use? Is it 6 3s3p
      • #48
        Is their a way to connect multiple mppt in series or parallel with different pv arrays top charge same battery bank
        • #49
          Each controller needs to have its own PV array. The controllers can be connected to the same battery bank (controllers in parallel), but please make sure you have good over-current protection. Some of the higher end models can communicate with each other and coordinate, but it isn't strictly necessary.
          • #50
            So is this accurate?
            With a 50A 150v max Mppt.the maximum combination (series/parallel) of panels 260W I can use? Is it 6 3s3p
            • #51
              Yes, three panels per string.
              You can put as many strings in parallel as you'd like (as long as combined isc is less than 50 A), but once you have more than two strings (6 total panels), you might start to see some clipping. That means the controller is no longer at the maximum power point, but instead increases the PV voltage to drop the power and hold the controller output to 50 A.
              You could probably go to three strings (9 panels) cost effectively, if panels are cheap. Facing strings east and west can reduce clipping and extend the charging day, if you have enough panels that you are clipping when they all face south.
              Edit: my comments on clipping were based on a 24 V battery. At 48 V, you could handle three strings (9 panels) without clipping, and consider adding more beyond that.
              • #52
                Sorry for the ignorance but trying to learn as fast as I can and the terminology. By strings you mean a combination of pv panels? Or sting is a set # of panels?
                • #53
                  String is a set of pv modules in series ( only series).
                  You then can rig strings in parallel
                  • #54
                    Suggestion: Buy a copy of "Solar Power Your Home for Dummies". $20 or so at bookstores/Amazon. Or: "Photovoltaic Design and Installation for Dummies".
                    • #55
                      The sarcasm is strong with this one
                      • #56
                        The DUMMIES series is actually a very good basic first step. They define a lot of terms, and put a lot of info at your fingertips. There used to be a free PDF of v1.0 floating on the web, but that may have been booted out. It's not that we want you to spend $20, it's that it's a huge resource till you get caught up on all the jargon and terms. There are likely examples of 2s4p string setups, DC combiner boxes [combiner boxes REQUIRED at 3p or more strings, fire safety thing) and as they say, a picture is worth a thousand words.
                        • #57
                          Well since we are in the books theme. Any good books about solar that you recommend (besides the above mentioned that I just bought)
                          • #58
                            Actually it is a good suggestion on how to learn about solar installations. Just because it has the word Dummies in it doesn't mean only Dummies should read it.
                            • #59
                              Nope .. There is so much crap and hype out there, I don't know of any others worth reading. Morningstar has some nice white papers on their site, talks about their charge controllers and sings the praise about their algorithms. But the papers are pretty decent and not too technical. (once you have the basics)
                              https://www.morningstarcorp.com/white-papers/
                              • #60
                                There was and is no sarcasm intended in that post. Sounded like you might have appreciated a point or two in a helpful direction. It was meant as a serious and respectful suggestion. It won't happen again.
