Most Popular Topics
Grid tied 1 panel
Originally posted by joejacksonIf anyone wants to know how to tie their panels to the grid. Here is a simple how-to video.
MSEE, PEComment
What I do not understand is why you are pushing back a Moderator when I am only trying to make sure the general populace that come to this forum do not do something that is beyond their abilities or can be dangerous to them or others.
If you have information that you want to share then please post it.
If you just want to be obstinate and opposed everything I post I will kindly ask you to stop.
I am very much in favor of solar and having it installed and used in a safe manor. Anyone that thinks everything they do is acceptable but may hurt someone if they do it is just hurting this technology.Comment
MSEE, PEComment
So I think it'd be possible to tell with a 250W panel and no consumption if it was that way for most of a nice sunny day.
Being in a rural Co-Op district you may in fact not have to putt permits with any AHJ, but that does not exempt you from any home-owner insurance policy requirements. If any part the the installation cause damages and you file a claim, the Insurance company will launch an investigation into the root cause of the fire. If they found out you installed it yourself without written permission and contract with the Co-Op, and notifying the insurance of changes you made without consent, they will not pay a dime.
I definitely wouldn't hook up that inverter to my house - and I would advise against anybody doing that.
I think that'd be more difficult to be sure that it was actually decrementing the kwh counter since it's not a nice analog dial.
I have given crender2000 a week vacation to think about what he posts.Comment
I have only flagged those posts which are: "harassment, fighting, or rude"
I think it's sad that you call me out just because it is inconvenient for you that one of your friends has been making such posts and you haven't taken action.
MSEE, PEComment
Mine wasn't - I watched it spin backwards and the counters decrement when I tested out my install before they replaced the meter.
For many people like me the "fix" for someone doing that is a use-once "lock" with a serial number on it.
Use a wirecutters to cut off the lock and you're presumed to have been stealing electricity.
Had to do some searching to figure out what it's called.
Looks these are called "plastic wire padlock"
Not really tamper-resistant - but good at being tamper-evident.
My guess is my POCO looked at "How much will it cost to replace the meters? How much electricity will we lose to thiefs and not recover? Ok, we won't replace meters already in service since that isn't cost effective."
I would guess my meter was from about 1975 when the house was built. And was replaced about 2 years ago after I did my solar install.Comment
Meter seals are easy to obtain. You just need to match color codes. Each color has a meaning. Black is used for Divergence meaning theft which tells the Meter Reader to inspect everytime the Meter is read. They will check the serial number each time that is engraved on the seal.
MSEE, PEComment
They're easy to obtain BUT difficult to open without it being evident.
Even if you replace it with an identical color/shape one (which is what I think you're alluding to) the serial number on it is still different and will be noticed. (maybe not immediately - but probably as soon as the usage is unusually low - or possibly they do a check once a year or when the utility bill changes to a new owner.)
Those seals are the main preventative of electricity theft in my area. They prevent both plugging in the meter upside down and accessing the wires before the meter (so you could bypass the meter) - or pull the meter and put copper bars in it's place)
It's not perfect - but my guess is it's effective enough that the more effective (but more expensive) avenues weren't worthwhile.Comment
Sean. If I wanted to ban you I would have done it hours ago.
It's just as shame someone else didn't share the same point of view, this forum would be an awful lot busier if he did.
Each to their own eh .....Comment
