  • Filter
  • #31
    Originally posted by FFE View Post
    One consideration: I am not sure what TOU plan you are on nor what utility you are connected to. But, I am on SCE TOU-A. I now have two EV's and this plan gives you a $0.09 per kWh credit for net used. I am a net user every month of the year. So even when their rates are higher during super off peak in the winter, I only pay $0.0437 per kWh for the amount used that isn't balanced out by credits from the rest of the day. In the summer I exceed the baseline and pay somewhere between $0.04 and $0.14 for my super off peak useage.
    I'm on the same plan (SCE TOU-A) and find it quite lucrative for my use case. The limitation with the $0.09 credit is that it stops after you've exceeded your baseline allocation. With 2 EV and 1 of them putting on over 100 mil/day, I will only see that $0.09 credit for a portion of my total super off peak usage. Nonetheless, excellent point and I'm glad to see others benefiting from the plan too.
    • #32
      Originally posted by maximizese View Post
      We paid $9,500 for a 4 year old VW TDI; the registration is $89 a year. We recently paid $7,300 for a 3 year old Fiat 500e; the registration is $453.
      Yikes! What year are they both? (And this is California, right?)
      17kw. I like science, but I'm no expert.
      • #33
        The TDI is a 2001. Registration has never been more than $150 (it started out really low because of campaign promises, but creeped higher later) and it was smog exempt until that also was reversed in 2010 IIRC. The EV is a 2013 and I'll pull out the remaining hairs on my head if this car requires a smog check at some point. And yes, this should by now clearly the state of California I'm referencing. Initially, I was peeved with the reverse on the smog exemption. They charged 3 times more for the smog check and seemingly did absolutely nothing; just a visual inspection with a dyno/sniff test. However, years later I found out some diesel drivers were removing their emissions equipment and modifying their fuel delivery systems to "roll coal." For the life of me I cannot get my head around the practice, other than for the sake of being obnoxious and revolting against the idea of a cleaner environment.
        • #34
          My 2002 Prius just had its first and last smog check last December. Initially hybrids were supposed to be exempt from smog for 10 years, IIRC. But I think they kept extending that because they couldn't figure out how to test emissions on a hybrid systems accurately. So was surprised when I got the smog check notice at my last renewal - but it was just a OBDII type check, where they verify all emissions equipment is reporting working properly, I think they didn't bother to try to come up with an actual tailpipe emissions test.
          I put in "and last" because my niece smashed the car into a guardrail last month, so the Prius is RIP now...
          • #35
            So I guess in both our cases, we had vehicles that were understood at some point to be smog exempt until they weren't (my guess was due to state revenue reasons). I suppose this can be extrapolated to utilities too with the ever-changing rates and fees; however, it is nice to have NEM agreements that can offer some stability and reasonable expectation. I'm sure a lot of us would be upset to sink $6K-$30K into a solar array and have the utility company change their structure on us. I've only heard of a few horror stories about customers not getting the interconnect approval, but those instances seem to place the fault on the solar installer.
            Sorry to hear about your Prius, I hope your niece came out unscathed.
