  • Filter
  • 6v or 12v
    Which is better way to go 4 6v 450ah Trojan Batterys or 2 12v 410ah Trojan batters ?
    I will use a 12volt system . ..which will last longer in life time . ..
    6volt will cost me $760 and 12volt $600 which is cheaper 160 dollars different . ..is it a big difference BTW 6 or 12 volt Battery ?
    thanks get back at me asap
  • #2
    What is the application ?
    Do you care about how many cell caps to check for water?
    Series batteries last longer than Parallel - any reason not to use 24V
    • #3
      My inv. is 12v system . .n to be real I want more power in 12volt
      more power in Batterys I keep read that 6v is better den 12v but wen I do the math is 40ah deffs btw 6v n 12v
      isn't it both last the same or the 6v last longer as I read...
      N no I don't think so about the water or should I care...
      am lost I read to much got 2much info n idk which is right or wrong...
      Doesn't it lower water is better as I saw...?
      thxz
      • #4
        I can't seem to find any Trojan 12volt 410Ah batteries. Only a 6volt which is the L16RE-B model.
        Are you sure Trojan makes that 12volt battery?
        • #5
          Yes 12v 205ah not 410ah
          by the way which is better Mppt tristar 60a or solar hybrid Mppt
          • #6
            The Mornstar Tristar MPPT is a good charger. I have never heard of the one made by solar hybrid
            • #7
              Thanks for ur time n ur info help me a lot I went on n get me 4 6v Battery Trojan 105re n am going to get 1 more 100watt plane so I can connect them in 2set of 3 and helpfully that will be the best way to go n stay power 24.7
              am going to set my battery up2day n don't use them until they r fully charged Cuz I know wen u buy them new it comes 50% charge so I will let them get full den starc using them....
              p.s. thank you again for ur time n info
              • #8
                You are welcome. Keep us informed on how your system is working.
                • #9
                  It is a stupid pointless question which deserves a stupid pointless answer.
                  There is no such thing as a Trojan 12 volt 450 AH battery. You would be a fool to run 12 volts. Use 24 volts and save $300 on the controller and another $100 on wiring. You are stuck inside a 12 volt box.
                  • #10
                    Umm..say u can see I said 4 6volt which me 2 6v is 225ah plus 2 6v 225ah = 450 ok dum ass b4 u talk understand wat u read b4 saying it...think twice b4 saying it
                    • #11
                      Before you type you need to understand the English language if you expect people to understand what you are trying to say. Your "dum ass" abbreviations are just a sign of laziness and illiteracy. I see in a couple of your threads you are starting to get defensive with people who are trying to understand and ultimately HELP you.
                      • #12
                        +1.
                        • #13
                          He is a highly educated Millennial. .
                          • #14
                            Hey ssunking how long will it take to charge 4 6v Batterys 450ah with 500watts n Mppt 60a
                            Right now I change my battery % n it shows 7.24volt each ...I just got 4 new once
                            soon I will but 1 more 100watt plane ..
                            • #15
                              At 7.24v per 6v battery I would say they are fully charged but I would first let them rest and then measure the voltage. That will get you closer to the % charge.
                              Of course using a temperature corrected hydrometer will give you a more accurate % SOC value.
