    • 14924
    Originally posted by peakbagger
    I like my adjustable angle pole mount, it took my 15 minutes to adjust the angle from Winter (30 Deg off vertical) to Spring (45 degrees off vertical). I have the two sway braces installed in winter to the corners of the array but for the rest of the year I only use one. If high winds are predicted I can always hook up the other one. Adjusting the sway braces take longer than actually adjusting the pole angle.
    FWIW, if I had a ground mount, which would have been my STRONG preference if I had the area, the array would have been a single axis adjustable similar to what you describe with probably a few variations, but the idea is to have adjustable tilt. My solar magnum opus residence I designed (but never built) out in the desert used a single axis adjustable ground mount array. In my book, if a PV array is considered, single axis adjustable ground mount offers the best way to go if at all possible.
      • 15125
      If all goes as planned, my pv system will be a ground mount and have a single axis manual adjustment. It won't be big since my home will be much smaller and much more energy efficient so I really don't know how big the system is going to be and a 6kw system might even be over kill.
        • 5198
        Pretty much my conclusions as well, plus additional requirements. The array here was supposed to be adjustable tilt, but I
        received no drawings in advance. What was built had the center of gravity so far from the pivot point, that seasonable
        changes would require a LOT of time, and equipment I didn't have. So currently I suffer some lost winter production
        and more snow accumulation.
        If you want to keep snow off, a ground mount seems a whole lot safer and more practical than roof mount. Stopping a
        huge buildup of snow in front of the lowest panel is just a matter of gapping the rows so most snow falls underneath the
        array; allows MUCH LOWER mounting and far less difficult snow removal. Bruce Roe
          • 15125
          Or just have the array mounted much farther South and avoid all the white stuff.
            • 3802
            seems like some massive voltage drop with that solution
              • 14924
              I'd have fired the drawing checker.
