I've had the darndest time seeking out the best PV for my application. Seems as if after each time I've found the right one I find something else. Specifically, I need 10 panels that are no wider than 32" but can be as long as 68", but I have found no online database that can be searched by panel dimensions.
I want the highest wattage I can fit, and that brings me to this comparison:
165 watts, mono:
Peak Power (Pmax): 165 W
Voltage at Peak Power (Vmp): 18.10 V
Current at Peak Powre (Imp): 9.12 A
Short Circuit Current (Isc): 9.58 A
Open Circuit Voltage (Voc): 22.81 V
Efficiency:18-19%
190 watts, mono:
Peak Power (Pmax): 190 W
Voltage at Peak Power (Vmp): 37.2 V
Current at Peak Powre (Imp): 5.24 A
Short Circuit Current (Isc): 5.88 A
Open Circuit Voltage (Voc): 44.6 V
Efficiency:15.3%
At first I was like awesome, Found another 250 watts!. Then, digging deeper, I realized the new find's poor efficiency and amperage. Does this matter though? 250 more watts is, after all, 250 more watts, and it doesn't matter if the PV is high voltage, low amperage, or low voltage, higher amperage as long as I size my strings properly. Is that correct?
165 watts, mono:
Efficiency:18-19%
190 watts, mono:
Efficiency:15.3%
