Putting in a 6.9KW ground mount grid tie system.
Looks like there's going to be about 200 feet of wire between my solar panels and my utility meter / breaker box.
If I mount the inverter at the panels and run my 240vac back, I have to run some sizeable wire to the house in order to avoid large voltage drops.
I could avoid the large voltage drops by running higher voltage DC to the house and put the inverter in the basement or on the side of the home, but then I have to deal with the New NEC codes requiring something called Rapid Shutdown..
What are you folks doing?
