You might be able to predict best-case lifetime from the battery's datasheet.
For instance, trojanbattery.com/pdf/AGM_Trojan_ProductLineSheet.pdf has a graph showing how many recharge cycles the battery can handle vs. depth of discharge. At 50% DOD, that Trojan AGM datasheet claims 1000 cycles. So if you were to charge them to 100% every day, and discharge them to 50% every night, the datasheet suggests they'd last three years. (For some definition of 'lasts'; not sure what Trojan considers too worn out, but maybe it's "falls below 70% capacity".)
Looking for a 100AH 12v AGM battery at the site you mentioned, I see something close: sustainable.co.za/media/pdf/SonX/SonX%2012V100Ah%28D%29.pdf Its "Life characteristics of cyclic use" graph suggests that at 50% DOD it would fall below 70% capacity at around 800 cycles... so something over two years.
So before you budget on an 8 year lifetime at 50% DOD, you should probably check the datasheet of the exact battery you're thinking of using, you might be disappointed.
If you can use even unreliable grid power to reduce the number of charge/discharge cycles (or DoD) you subject the batteries to, you might extend their life quite a bit.
The batteries I saw at sustainable.co.za with a ten-year warranty were rather expensive LiFePo4 ones.
Caveat: I've never done an off-grid solar system. My only really hands-on experience with batteries is trickle charging NiCd's and lead-acid batteries when I was a kid, and the main skill I'm using here is knowing that spec sheets exist and that they're worth paying attention to... and that here be dragons You'll want better advice than mine before making decisions. Have you checked the sticky posts at solarpaneltalk.com/forum/off-grid-solar/batteries-energy-storage/lead-acid yet?
