I know that the MSP line of inverters can be ac coupled so that when a power outage occurs the magnum can put a sinewave back into your now disconnected home wiring and turn grid tied inverters back online. This power is then used to charge the batteries on the magnum or to power loads.
I can't find documentation on is if multiple magnum inverters can be stacked together on the AC side. Since the magnum does frequency shifting to regulate the power output from the grid tied inverter wouldn't having stacked magnums cause an issue?
The only thing I can think of is if the magnum router can sync both inverters so that the shift of one matches the other.
