Announcement
No announcement yet.
Problem installing PV system with battery and common generator
  • Filter
  • #16
    Originally posted by PNW_Steve View Post
    What is it that is different from the power generated from a "prime power" generator that keeps it from appearing the same as utility power?....
    Impedance. A generator has much higher impedance than a Grid. Some of the grid qualification testing involves frequency stability and some involves Grid Impedance. It's testing for 5 minutes, and only needs one fault to reset the clock. And if it does somehow pass, and your loads drop off, how does your generator deal with 5 or 10kw of power being pumped into it ? Will the inverter shut down first, or will the generator fry ?
    • #17
      I forgot about impedance... Inverters that are AC coupled are able to simulate this as well.
      • #18
        No need to simulate it. A bimodal inverter has batteries thus giving it all it needs to simulate a valid grid for the inverter that is AC coupled.
