I bought a Nature power 1800 solar system with 2 extra Battery's because it was on special but had not done my research I also have 6 grape solar 100w panels that i am planning to use with a Sun 1000W Solar on Grid Tie Inverter with Power Limiter DC 22-65V to supplement by grid power usage.
The Nature power 1800 is basically three 12v 80Ah lead acid battery's each with built in solar chargers each connected to a 100w Panel (and connected in Parallel)
I would like to use the battery's at night connected to the Grid tie I think I can build some jumpers so that I can connect them in series or use a DC to DC converter to boost the voltage
Please recommend best way to achieve this, manual change over switch? etc.
Thanks in Advance for any recomendations
